Besteady One
http://www.ebay.com/itm/171733105134?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
$1,990 O.B.O.
I found myself needing a gimbal to support larger cameras, so I’m selling my used Besteady One that I’ve been using with my Panasonic GH3. I purchased it via Quickstarter on 2013 without the factory handles, so I customized my own using express35 parts
What I liked the most about it:
The foam of the base where you seat the camera on is damaged, so I just added a piece of plastic to make sure it doesn’t twists on me.
I’m including the following:
I spent $220USD on the 2 extra batteries and charger.
You can download the manual from http://www.acr-sys.com/download/BeSteady_OnePlus_Manual_v1_0_hires.pdf
Here are some specs:
[TABLE="width: 697"]
[TR]
[TD]Mainboard
[/TD]
[TD]8-bit custom SimpleBGC / AlexMos
[/TD]
[/TR]
[TR]
[TD]Sensor units
[/TD]
[TD]1 Inertial Measurement Unit: 3-axial gyro & 3-axial accelerometer on camera shelf
[/TD]
[/TR]
[TR]
[TD]Number of profiles stored on board
[/TD]
[TD]3 profiles
[/TD]
[/TR]
[TR]
[TD]Camera cage
[/TD]
[TD]Two simple aluminium cheeseplates
[/TD]
[/TR]
[TR]
[TD]Balancing
[/TD]
[TD]Completly tool-less balancing
[/TD]
[/TR]
[TR]
[TD]Camera weight range
[/TD]
[TD]From 0,5 kg to 2,0 kg (from 1.1 lb to 4.409 lb)
[/TD]
[/TR]
[TR]
[TD]Camera cage sensor enclosure
[/TD]
[TD]Two piece aluminium box
[/TD]
[/TR]
[TR]
[TD]Weight
[/TD]
[TD]Basic option without Antivib: 1,07 kg (2.359 lb)
[/TD]
[/TR]
[TR]
[TD]Main power cable
[/TD]
[TD]Bare wires, JST connector
[/TD]
[/TR]
[TR]
[TD]Rear arm electronics housing cover with LEDs
[/TD]
[TD]Transparent plexiglass
[/TD]
[/TR]
[TR]
[TD]USB connector on mainboard
[/TD]
[TD]Revision 1: solder in two points, revision 2: solder in two points plus two positioning towers
[/TD]
[/TR]
[TR]
[TD]Manager App
[/TD]
[TD]From 1.0 to 1.3.3, 2.0+ after firmware upgrade
[/TD]
[/TR]
[TR]
[TD]Classic Stabilisation mode
[/TD]
[TD]Available, old version of strict stabilisation
[/TD]
[/TR]
[TR]
[TD]Xtended Stabilisation mode
[/TD]
[TD]Available, new version giving wider operational range
[/TD]
[/TR]
[TR]
[TD]Follow mode
[/TD]
[TD]Available, selectable for Pan, Tilt and Roll
[/TD]
[/TR]
[TR]
[TD]Special connectors (combs)
[/TD]
[TD]One 6-pin comb for RCU or Thumbstick
[/TD]
[/TR]
[/TABLE]
Feel free to ask me any questions you may have.
The gimbal is in fully working conditions. Returns are accepted only if there’s something wrong with it and it’s not stated in this post.
Tags: Ronin movi defy helix letus came freefly eagle Steadicam tiffen merlin blackbird flycam glidecam
$1,990 O.B.O.
- It takes cameras up to 4.4lb (2kg).
- The balancing is tool-less since it uses thumbscrews
- It has up to 3 profiles that you can switch in between just by clicking on the control button.
- The footage is very smooth and I only had issues when I didn’t balance the camera properly.
- It is very lightweight compared to the rest in this range, around 9lbs.
- I was able to change the zoom of the lens without rebalancing to tilt axis. I used the Panasonic 14-140 lens which extends as it zooms. I balanced it for a 35mm focal range and I was able to work on the 14-50mm range without a problem.
- Battery life. I was able to shoot a 12 hour wedding with just 2 batteries making sure I didn’t have it on when it wasn’t needed, but with the 4 batteries I’m including you could work on long shoot or an entire wedding without a problem.
- If you need a more free access to the top part of the camera, you can take the top part of the cage off.
- No need to do any programming, just tweak settings in the desktop manager application.
- Besteady One
- Cinestar adapter (for drone use)
- Express35 Rig (the besteady is attached to this via 4 thumbscrews)
- 4 batteries. I purchased 2 extra batteries myself, the black ones
- 2 chargers. I purchased 1 extra charger.
- Silk mini-quick release adapter. I do have the quick release plate, I just forgot to take it out for the pictures.
- Xit XTHC40 Medium Hard Case. Forgot to take a picture of the actual case but I’m adding a stock one.
[TR]
[TD]Mainboard
[/TD]
[/TD]
[/TR]
[TR]
[TD]Sensor units
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[TD]3 profiles
[/TD]
[/TR]
[TR]
[TD]Camera cage
[/TD]
[/TD]
[/TR]
[TR]
[TD]Balancing
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[TD]Weight
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[TD]Manager App
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[TD]Follow mode
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[/TABLE]
