You can shoot 60fps, but it's a little different. You have to go in and change the base frame rate from 24fps to 60fps. Basically, with S&Q when recording internally, it has 3 frame rates - 24fps, 60fps and super slow motion. With the 7Q, S&Q only has 2 frame rates - 24fps OR 60fps and Super Slow motion..
Thanks! So I need to set output format of the camera to be 2048x1080 / 60p? I understand that 60p halves the bit rate internally, so if I'm recording internally simultaneously to the 7Q, the files internally will be at a lower quality? Is this optimal way to get 60fps on the odyssey? It's not at a 24 FPS base?
