Hi,
I´ve been searching the forum (and the rest of the web for information on this topic but I still can´t figure out the best way to solve this issue.
We are going to shoot a school class photography cinemagraph style (a short clip, at first appearing like a still image, where a small part of it is moving). The scene starts with a still image of a class with one chair empty. Then the missing student enters the frame from the right, walks diagonally towards the empty chair, sits down and finally blends into the still image. I guess this would be quite easy to achieve if we were only going to use a film camera. We´d just tell the other students to stand real still for the shot and freeze one frame in post production. Then we´d make a quick matte around the moving person and we´d be done. However, the production also calls for print images to be made. Unfortunately no film camera resolution will be enough for this use. And this is where things are getting complicated for me.
The still image of the class will be shot with a Hasselblad camera to achieve the highest possible print resolution. Our plan is to place the film camera on the same spot as the still camera, using the same focal length and light, to capture the sequence of the student walking towards the chair and sitting down. Then we will match the grading of the film sequence with the still shot.
Now, what is the best way of keying out the person in the film sequence in order to place it above the still shot?
1) all green screen wall/floor with the problem of green spill onto the chair and actor
2) green screen wall behind actor and rotoscope the floor shadow/reflection manually, trying to match position and color of the film sequence with the still shot.
3) another solution that hasn´t occured to me
I´ve attached a shot from the location where you can see the reflectiveness of the floor.
Kind regards
Kind regards
