bownut Active member Jun 5, 2006 #1 Any preference on the best brand to use for shooting in the 100B?
HorseFilms Look ma no hands Jun 5, 2006 #2 I use Panasonic Master Quality tapes and have had no problems.
S SilverWolf Veteran Jun 5, 2006 #3 I've used the Sony premium tapes and the've worked no problems Just make sure you pick a brand and stick with it
Ian Slessor Well-known member Jun 5, 2006 #4 I echo HorseFilms. Panny MQ tapes and Panny MQ tapes only. I also concur with SilverWolf. Regardless which brand you pick, once you pick, stick with it. Or have a pro cleaning done on the heads before you switch brands. ian
GageFX Carbonite Member Jun 6, 2006 #5 I use the Pan MQ only and I've never had a dropped frame on a first use tape, and I've reused some tapes up to 4 times and I've never had more than a single dropped frame from an an entire hour's footage. I certainly trust the Panny MQs. -GageFX
t-h-e-w-h-o Well-known member Jun 6, 2006 #6 i use panasonic PQ tapes and ive never had an issue with em either.
