Best settings in Clubs with not much light
bounce187
Hi,
here is your german Friend with the bad english.
Im searching for the best settings for clubs.
I dont like to shoot with a led-light because without a led light the videos have more club-atmosphere.
i am aware, that s-log has the best dynamic range but for the best results s-log must overexpose about 1-2 stops and that ist nearly impossible with so bad club-light (except i go to ISO 80.000).
so i need a picture profile that works good for me in ISO 6400 - 12800 with a high dynamic range and good for postproduction. a profile where i can a little bit underexposed without much noise.
i hope so much that you understand what i mean :D.
you all are very friendy to me. thank you so much!
best wishes
johannes
The most important thing is: make sure you set WB at 5000ºK or higher, or you'll get the nasty blue clip thing.
Also, I wouldn't try to get the image "properly exposed". Clubs are dark so the video has to look dark. I shot this with my 5N at ISO 1600 and f/2.0, and then had to bring the image down in post!! Since I use slog overexposed 1 stop, if I had to shoot that again with the a7s I would probably go for ISO 6400 and f/4.0.
^ Well, it depends on how you want the bright spots to look.
Regarding underexposure: I wouldn't be worried in this case, you're probably going to push the mids down to keep a "club" look and that will clean most of that noise. If you can afford a test before the shoot, I think it would be a very good idea. Try every option and see what you like.
