studio1972
Currently I have an SD100.
Options are:
1. Stick with the SD100
2. HS300
3. HMC40
4. another HMC150
My thoughts are:
SD100 - Cheap, not great in low light, can mount a Vidiomic, records 25p with cine gamma
HS300 - Fairly cheap, probably not great in low light but possibly better than SD100, 50i only.
HMC40 - Not cheap. Similar to HS300 but with 25p and XLR option, possibly more manual control, although probably not as much as the 151. It looks more pro than the first 2.
HMC151 - Good in low light and ample manual controls. More expensive than the HMC40 but maybe not too much more. More impressive to clients as it looks less like a consumer camcorder. No issues matching image as both camcorders will be identical.
Summary - probably stick with SD100 for now due to finances. Save up for a HMC151 when I can afford it. Was really hoping the HMC40 would be a bit cheaper, but it seems like it would just be better to save a bit more money and get the 151 rather than get the 40 and regret it's shortcomings.
At least that's what I'm thinking based on what I know or can assume at the moment.
Options are:
2. HS300
3. HMC40
4. another HMC150
My thoughts are:
