Edrafennas
hello! Congratulate me with the acquisition f35 !!
I immediately raised the question better recorder ! please advise! Odyssey7q? pix240? gemini444? sr-r1? Thanks!
I don't recall which of our six updates this year included it, but the Odyssey7Q can now generate it's own timecode. All in the menu and pretty straightforward to setup.I own a Gemini, yes it'll do 50p 422 from 1 IF just fine, the dpx frames get spanned across 2 ssd cards, odd frames on one, even frames on the other. The LUT Box gives us a 12bit 444 uncompressed option for 24p. Got it for a bargain with 6 256Gb cards.
We also have a 7Q here that we can rent for cheap too. The 7Q does everything that the Gemini PLUS Prores HQ up to 50p, which is nice for projects that ask for a compressed workflow.
The problem with both Convergent Design recorders is that they expect some sort of timecode input (either through SDI or 5-pin LEMO) since none of them generates timecode themselves. The F35 does not output timecode by itself (the SRW-1 was in charge of such task). This makes conforming in an online/offline workflow for a long form project a headache.
The Sound Device Pix240i is a nice little piece of equipment really, solid build, timecode, 12bit Prores4444. But it doesn't record pass 30p for 1080p.
So it really depends on what kind of shoots you have most of the time. Before we have the 7Q we'd just have our DITs convert the DPXs straight from the cards into the disk array to a compressed flavour (usually Cineform) on set using Davinci Resolve without a noticeable penalty on time.
All in all the SR-R1 sounds like the best option (good compression, timecode, reliable media) BUT it's a power hog and it's heavy, and then you'll some sorts of monitor too and the cheapest SRMemory cards are still expensive (so is the card dock). There're always trade-offs.
Hello everyone. It took me a very long time and quite a bit of money, but I have recently procured a complete Codex Onboard M Recorder setup. The setup includes the active mount that connects to the recorder through the multi-pin interface directly on the F35, data packs, and, very importantly and very difficult to find, the data transfer unit to download the material at high speed. I previously tried to download the footage via the Ethernet connection from the recorder itself, however the maximum transfer speed I have ever been able to achieve is 1 fps (each frame is about 9.3MB) - much to slow to be useful. With the data transfer unit I am able to download 100GB in about 30minutes (to an external hard drive, so that might be a bottleneck).
I am still testing it and did not have a chance to take it out into the wild to capture some decent footage to share here. Unfortunately (well, fortunately really, but fortunate for the tests) I will be away for 5 weeks beginning this Sunday and therefore the testing and sharing of some footage will have to wait until sometime in February. The information I have gathered in the limited time using it and that I can share for now is that the Codex receives all the camera information - timecode, start/stop trigger from the camera, under and over cranking, ramping, and metadata. I have been able to set the camera at 1fps and ramp up to 50fps maintaining exposure and when I offload the material the Codex application automatically converted a copy to Quicktime Prores 4444 with the correct speed throughout the clip. I have to say one of the greatest things about the Codex is the application that automatically creates different versions of the footage in realtime (you can easily setup what versions you want). Of course the main reason I got this recorder in the first place is that the it captures gorgeous 12-bit 444 up to 30fps and 10-bit 444 up to 50fps. Finally, it doesn't seem to require that much power - I am able to power the camera, recorder and an Ikan d5 for about 90 minutes on a generic 150wH battery.
If I get a chance to shoot something tomorrow (unlikely) I will post links to the original uncompressed 12-bit files. With this post I just wanted to give a heads-up that there is someone here with a Codex system that will soon write a thorough review of this setup.
Cheers and Happy Holidays to everyone.
Igor
