dajavudesigns
Best place to buy a cheap quality frame for a 20 X 20 ft green screen?
Thanks.
Thanks.
For a 20X20 PVC is way too flexible. You should use 1 1/4" speed rail and just buy these: http://normsgrip.com/index.php?dispatch=products.view&product_id=29845. With the discount Norm's offers the mounts and corners are $475.
Chris,
Your quote:
"PVC contains phthalates, lead, cadmium, and/or organotins, and manufacture or burning of it results in *dioxin* added to our ecosystem. It should be banned. Avoid."
I had better rip up all the hundreds of feet of PVC pipe around my property from well head to house and irrigation lines and replace it with what:
cast or ductile iron = expensive and heavy, not readily available in home owner sizes under 2"
galvanized steel = limited life when buried and heavy on the zinc
stainless steel = VERY expensive
Bronze = even MORE expensive
Copper = not suitable for direct burial
And your practical suggestion is??
I am not saying PVC is without health and enviro hazard, but the alternatives have issues also and or aren't practical.
Grant
As far as the OP question goes, sch40 aluminum pipe will work great and could also double as dolly track.
Would you be willing to spend thousands to replace the PVC on YOUR property?
