nick_m_777
I currently have an older model HVX200 (HVX200P) and am making some equipment upgrades before my next documentary. Just looking for suggestions or comments from others with more experience than I on how I can improve these area with the most "bang for the buck"...
AUDIO
I'm significantly upgrading my audio setup. Have always used just the lavs that came with my Sennheiser EW100 wireless setups for interviews. So I'm thinking I'll step up to an excellent shotgun (like the Neumann KMR81i) and Tram TR-50 lav's as backup for interviews (hard wired whenever possible, wireless when necessary) running into Sound Devices 302 mixer. My shotgun operator is not very experienced, hence backing it up with lavs. Suggestions/comments?
But I also wanted to do something to upgrade my image quality. I understand that lighting is a major make or brake factor.
LIGHTING
I have been lacking in this area due to budget and experience (basically a couple Lowel Pro lights, the smallest Rifa, and some reflectors). So I will be upgrading lights and I'm trying to continually improve with my lighting technique. Will probably get a fresnel (650 watt?) and maybe an omni? More than that? Suggestions/comments?
CAMERA
I've been out of touch with the camera market since my HVX200 arrived. So I've been looking around and find that it looks like they improved some of the areas I've had concerns with--noise and low light performance (but especially the noise) in the HVX200a. I also see the intro of the HPX170 (essentially a tapeless HVX200a with some nice pro features) and the HPX300 (full res chips, more pro features, improved sharpness and less noise). I have also been thinking long and hard about a 35mm adapter as I have had such a difficult time getting that shallower DOF with my stock HVX200.
Here's my question...(If you were in my shoes) would I get the most bang for my buck in improving the image by going with a 35mm adapter on my current older model HVX200, or by going with the HPX170 without the adapter (no budget for both right now). Or do you think I should just save my $$ until I could go with the HPX300? Or just stick with what I have and put a ton of $$ in lights & accessories?
Many thanks for your suggestions!
AUDIO
LIGHTING
CAMERA
