Best Case for air travel with FS700 and oydessy
LDV20
I will be traveling and I already have a very large pelican - but want something smaller to carry on - containing FS700 and odyssey and some batteries ect.
I think I read that 1500 series pelican cases did the trick. Wondering what others were using and or doing
thank you
If you get the 1510 with dividers. Take the lens off the FS700. And stand the Odyssey upright, you can get it all the fit. It'll be tight, especially if you want to bring lenses, cage, etc...
Thank you - I was thinking of that. I can put lenses and other equipment in backpack. I will also have a big pelican case for accessories that I will check in - main concern is protecting camera/oydssey in 1510 - the 1510 can be carried on, right?
thank you
The 1510 is definitely quality and can fit FS700 plus many accessories. As mentioned, it is sized for carry on. However, many users have stated that in certain airplanes or in certain countries it may be considered oversized. An alternative is also the think tank.
http://www.bhphotovideo.com/bnh/con...&m=Y&c3api=1876,92051677442,&is=REG&A=details
It is not as robust in terms of protection, but it will fly well in just about any scenario and it looks less conspicuous to thieves looking for Pelicans filled with expensive equipment.
I suppose it depends on your needs. And the pelican will be more versatile day-to-day when not traveling.
Yes - I will check on the size and see if it might be oversized for some planes. I will also take a look at the think tank -
thank you
Larry
