gillatineny
I'm doing a webasode interview of a band in their hotel room. The last interview I did I used two different wireless mics for both the interviewer and the interviewee. I didn't like the difference in audio, had to use two different brands, the audio simply didn't match. I now only have the option of using a condenser mic and/or a shotgun mic. I will have a host interviewing two people in this band. Should I just use the shotgun mic or try to mix in both? any suggestions?...what would you do with these two resources. Also i will be filming on an hvx-200. the shotgun is only for the hvx. Plus the hvx is the only camera I have that has XLR outputs, so its my only option for my condenser as well. Also the other camera I want to have moving around and having a wire would get in the way.
Any opinions/suggestions are valued.
thanks
-sean
thanks
-sean
