Barry_Green
Moderator
Found this link over on dvinfo.net:
http://thebrownings.name/WHP034/pdf/WHP034-ADD38_Panasonic_HPX301.pdf
Adam Wilt at provideocoalition wrote that DRS 3 can produce some unwanted artifacts at times, so he did not recommend to have it always on, but BBC's evaluation does not have any warnings about that.DRS 3 and a master pedestal of +3? Huh. Who would've thought?
All I could find were the Sony guides: http://www.bbctraining.com/onlineCourse.asp?tID=5160&cat=2781I wonder if they've ever done a document like this for the DVX?
Haven't put the 300 next to the 3000 but I wouldn't be surprised at 2 stops different.
The 720p looks fine from the HPX300 but I'd always shoot 1080/24p whenever possible; 720/24p provides a good alternative if you're trying to reduce any skew effects. I'm sure a downconversion in post would be superior to one done in-camera, provided your downconversion program is a good one!
I think in all the stuff that I've shot on the HPX300, something on the order of 90%+ was shot in 1080 mode. I do like 720/60, but for filmic stuff I way prefer 1080/24, so I don't have a lot of 720p stuff to compare.
I don't know what the "improve motion captere" line refers to.
I suspect a lot of engineers see stuff the rest of the world never will see what so ever. Appart from great thecnical knowledge, they usually have access good test and measuring equipment. This also should pinpoint any potential problems when pushing the final master trough transmission.He's very technical and doesn't view things in the same way that perhaps the average dvxuser might. (He talks a lot of aliasing etc that I've never seen .)
It's caused by diffraction, and every 1/3" camcorder (or smaller) will face a similar issue, no matter what lens you use. It's best to avoid stopping down past about f/4 if you can avoid it.
In the olden days we used to know that the smaller you set the iris, the sharper your focus got. That's changed with small-chip HD cameras. Now, there's a limit -- go past about f/5.6 and you'll start seeing your image getting softer and softer.
