Battery used when shooting high frame rates?
GREEN_RANGER
Hi Guys,
Just wondering which batteries people use and recommend to power their 7q/7q+ when shooting high frame rates in the field when ac power isn't available? Im using the SWIT S-8972 batteries for normal use with the recorder. Just wondering if anyone has any experience with these batteries, and if they'll hold up when shooting high frame rates?
I use an Anton Bauer Dionic 90 with PTap to Convergent power cable. Lasts far longer than the media does.
e
Thanks, am trying to avoid the bricks to keep it more lighter and compact. Just wondering what the max running time can be with non v-mount/anton Bauer batteries?
it's possible to use those batteries, as well as original sony L batteries - but bear in mind that at such a high power draw, you'll need at least 6 batteries a day.
I always shot with Sony L's on the 7Q and with 3rd party batteries on the camera. the original Sony batteries seem to hold the maximum voltage way longer than the cheap ones. Sometimes i wasn't even able to record more than 3 seconds of 2K HFR on the Odyssey using the cheap batteries - then the screen goes black or bonkers - at least that has been the fact half a year ago - since then i switched over to V-Mounts, 2 bricks a day for everything. period.
3 seconds!! Wow thats crazy. I've been testing the SWIT S-8972 batteries, and they seem to hold up ok when shooting 2k at 240fps. Not sure how it will cope with the 4k slo-mo burst mode though :S I've been told that the Watson L series batteries and sony U batteries are a good option as well, however the sony U batteries would require buying another battery plate for the odyssey. 2 bricks for everything sounds good actually. How compact can you get the fs700, 7q, and a v-mount battery setup i wonder?
Another thing to consider is that with the vmount/Anton Bauer setup, you can better balance the camera for handheld shots. I don't place my brick on the back of the 7Q+, but rather, at the back of the camera.
+1 what bitnaut said.
well, as i said, it greatly depends on the quality of the batteries you use. I'd expect the swit batts to have similar performance to the sony L's.
I believe the 4K 120p Burst mode the shot over to the ssd's @60fps, half the speed than it was shot on, hope that makes sense. Anyway, i'd expect the power draw similar to 4K60p or 2K240p in 4K 120p Burst mode.
4K120p Burst is in fact about the same power draw as 4K60p. HD240p is a slight bump up in draw.
U-series batteries are more effective because they are 14.4v, so we drain more juice out of them before they drop to a point that they need to be swapped out. But one large battery is certainly more efficient than several small ones.
