Batteries for the EX1 - which is better?
Lor
I'm using this one: http://mxmexpress.com/product.php?id_product=9 . Lasts for 7 hours. No problems yet (Close to 150 hours).
Edit: Also i wouldn't suggest buying a battery with an on/off switch on it (dunno if it's for the backlight of the lcd tho'.). Imagine during a record you press that accidently :/
The 95Wh last much longer than the 65Wh; however, all of those 95Wh batteries are from China. I'm not sure if I can trust Chinese products. Does anyone know of any batteries that are 95Wh but are made or located in the US?
The US made ones are made by Switronix, we have not had any complaints so far. The company is in NY area, so if there is an issue, they are easy to reach. Keep in mind that they (all 95Wh) are real big and heavy, almost proportionally so with the increased capacity.
Thanks for the information. Is the size much bigger than those made in China (showing in the links I posted above)?
For the same WH capacity all the batteries no matter where they are made will be about the same size and weight. Some no name manufacturers tend to label their product more aggressively than the reputable ones.
