Denniscasey
Experimenting with Scene File settings I can't get Color Temp to work. I can get other settings to work--for instance I can adjust A.Iris Level to lighten/darken exposure and I can see scene get darker/lighter when I adjust A. Iris Level. I set to minus 6 (darker), do Save and then Load and turn off camera and when I turn it back on scenes I look at have dark exposure.
But, when I try Color Temp I can not see color cast/tint change in viewfinder when I do adjustment and when I do Save, Load, on/off there is no change to color tint (bluer/oranger) in scene. By the way, in my HMC40 there is an Enter selection for each setting which I do (that step was not mentioned in the Panasonic tutorial or in Barry's book). Barry points out page 239 of his book that A.IRIS and COLOR TEMP only take effect if you use auto-iris and manual white balance.
My procedure is set camera to Manual; push iris wheel until Auto Iris displays, do a manual white balance and then try adjusting COLOR TEMP but is there something else I need to do or it only works in certain lighting or what?
Also, I am still not clear on how long Scene File settings are applied. Once you do initial on/off to "set" Scene 1 or Scene 2 are they in effect from then on no matter how many times you turn camera on/off and are they only in effect if you are in Manual setting? Thank you, Dennis
