Basic field monitor?
therealodwyer
Hi folks, I'm new to the forum. I've been a viewer for years but I've only signed up today as I figured this was the best place to ask for advice!
I've done a search and all I find are threads specific to a certain monitor, so I started this to hopefully hone in the broadest advice, not just advice about a specific monitor.
Essentially what I am looking for is a 6 or 7 inch field monitor that I can place on an arm off the AF100. It doesn't need to have scopes or meters, it just needs to give me a larger picture to monitor from. I'm working with The Global Fund, an organisation that fights against Malaria, TB and AIDS/HIV, so the camera will be going to places from deepest darkest hottest Africa to India in the monsoon season, so the monitor has to be rugged enough. It would also be great if it's not a heavy bastard, and if it can be a simple setup plug and play sort of thing.
The camera's been taken on a few trips already to PNG and the Solomon Islands, and watching the footage I'm finding that the previous camera operator had quite a bit of trouble keeping some of the shots in focus, or he would have the focus on the background and not on the subject. I'm guessing this is because he came from a HDV background and wasn't used to working with depth of field and photographic lenses, and the focus assist can only do so much on the tiny LCD if you're not comfortable with shifting focus in the first place. So I'm trying to source a fairly cheap (as far as cheap goes when talking of monitors) monitor that the next camera op could easily shove on an arm off the camera, with a sun box on it so he/she can constantly have a larger picture and keep focus more effectively whilst on the go. The budget is at a maximum of 1000$, so really all I'm after is something that will give a sharp feed of the picture on a bigger screen, that's all.
With hope that some of you fine folk will help,
Best,
David
I can suggest you strongly the Lilliput 5d-ii/O/P monitor, 7"; it is cheap but it's a big value monitor. It has a good definition (1024*600), good contrast, acceptable colors, focus peaking, zebra, false color, histogram and pixel mapping 1:1. It has a good built-in sunshade and you can power it in several ways. The only limit is that it has only HDMI input. The price is about 300 USD from eBay
Regards
Gary
The Lilliput comes with a ball head included in price. The ball head can be attached to the AF100 hot shoe, but in this way the camera is unbalanced. In the package there is an allen key and a 1/4" screw: you can dismount the hot shoe attachment on the ball head and insert the screw so you can attach the ball head the monitor to the screwed holes on the AF100 handle. In this way you don't need an arm. Additionally there are cheap chinese articulating arms on eBay: they work well for this job and you can find it in 7" and 11" lenght. They are very cheap, so you can buy both and then you can use the lenght that is more comfortable for the location or for your needs.
There are a lot of models of Lilliput monitors: be sure you take the 5d-ii/O/P. You can save 700 USD on your budget and the monitor is more than enough for your needs. If you want you can use the saved money to add an EVF like cineroid or zacuto or small HD for an optimal monitor setting in every situation (monitor + EVF for the same budget): this is my setting and I'm very happy with it
Regards
Gary
Regards
Gary
Why not a EVF instead?
No weight or balance issues, works better outdoors, much more compact, less power hungry, & easier to transport.
