OK. So maybe it's the fact I've been working for 18 hours straight and my mind is partially play-dough, but I'm thoroughly confused right now by what I think may be the dumbest question ever.
Anyway... here's my problem and my workflow.
PROBLEM:
Stupid black box above and below my 1080 footage after I export to QT out of FCP (this box never existed in my 720 footage)
WORKFLOW:
- I have 1080/30p footage from a Canon 7D and Rebel T2i
- Converted to Prores 422 in MPEG Streamclip (I can never keep the file system intact to use the FCP EOS plugin. I need to work on that)
- Imported into FCP7
1080 SEQUENCE SETTINGS:
Frame size: 1920x1080 HDTV 1080 (16:9)
Pixel Aspect Ratio: Square
Field Dominance: None
Editing Timebase: 29.97
Compressor: HDV1080p30 (Also tried ProRes)
Quality: 100 percent
After I export to Quicktime with current settings, the video plays back with a small black bar above and below the footage. Weird. This seems kind of normal to me, except these bars never existed when I edited in 720. Not that it looks bad, I'm just confused why the bars are there when they weren't there in 720.
720 SEQUENCE SETTINGS:
Frame size: 1280x720 HDTV 720p (16:9)
Compressor: HDV 720p30
When I export this, no black bars above and below.
So why -- If my settings are basically the same except for the 1080/720 substitution -- do I get the above/below black boxes for 1080 and I don't get them for 720?
I don't think I want the box. Don't like the box. The box is bad. I think.
Thanks.
PROBLEM:
WORKFLOW:
Thanks.
