F55: Base-plate mount
Backfocus92
Can someone tell me if the Element Tech. baseplate for the F3 will fit on the F55? I have the baseplate for the F3 with a micron system (took the standard riser off) that I use on the F3. I am renting a F55 soon and need to know if the base-plate will work, since the rental company does not have a shoulder mount system for the F55 yet.
Just shoot ET an email and ask. Vivian there is very helpful. From memory I seem to recall seeing on mounted on a pre-production F55. But I imagine you'd need the F55 shim plate (rather than the F3 one) in order to connect it to the camera and have correct rod height.
