Hi all,
I have a gh4 with lumix 12-35mm f2.8 and have recently acquired a Devin Graham Glidecam but am having a few issues stabilising it properly.
Obviously these things were designed for much heavier cameras (although the minimum weight spec says 900grams) but im hoping to find some folks who've managed to perfectly set it up despite its light weight.
The general consensus seems to be to put two counter weights each side on the base (4 total) and leave the fins fully in (not extended). That automatically makes the base very heavy. Apart from the camera and lens (about 865grams) I have also added an ND filter, a different quick release plate on top of the included quick release (to match my tripod for easy changing) and 1 counter weight. I estimate the top weight to be about 1100 - 1200grams and I'm using a drop time of about 2.5 seconds.
I seem to be able to balance it okay statically - standing still it stays level and doesn't sway - but am having great difficulty achieving what is termed "dynamic balance" - I.e when you walk and come to a sudden stop the Glidecam should also come to a complete stop and not keep going by rolling forward or back. This seems to be the biggest problem for me and I'm hoping some folks on here might be able to give some advise ???
Many thanks
Many thanks
