Brian_Broz
Hi,
I'm wondering if for a cheap backup solution I could acquire on the HVX at 1080i (with it's progressive "look"/gamma/true 16x9) and then transfer (or ideally live stream) to the Sony HVR-M10u VTR? Yes, I know it's HDV but it could solve a lot of potential problems or help backup material in an affordable way.
The M10u has Firewire in, a 3.5" 16x9 LCD, is battery operable in the field (Sony L series). My thinking in this is that is you shoot in 1080P it goes to tape at 1080i regardless, which the M10u deck records in (either 50/60i). You would get all the advantage of the "look" of the Panasonic, but for jobs that don't require keying/4:2:2 but more importantly longer record times this may be a great solution.
Just a thought as I was using an M10 on set the other day and it's a real handy device.
Just a thought I'd pass on. For those that have used HDV extensively (as I have) it's actually surprisingly good...if you treat it right with your camerawork. Despite there being so many negative comments on these boards...those of us who have actually used HDV and seen what it's capable of (in the right hands) it would be a viable tape backup solution if it will accept the firewire at 1080!?
Hope people find this suggestion useful...and any comments are appreciated.
Cheers,
Brian Broz
Vancouver, Canada
Cheers,
Brian Broz
Vancouver, Canada
