Backfocus slightly out on my DVX: can I still use a 35mm adapter?
dan_aka_jack
This is a slightly odd question...
The backfocus on my DVX100a is slightly off (i.e. the backfocus of the DVX's built-in zoom lens... nothing to do with a 35mm adapter). I've taken the decision not to have it repaired because the problem is not too bad so I can work around it and because I'm going to put the money saved towards a nice Marshall LCD monitor (i.e. if I can precisely judge focus on the Marshall then I can make sure my DVX is always in focus even though it has a slight backfocus issue).
As I understand it, having a slightly off backfocus on my DVX wont affect me at all when I'm using a 35mm adapter - is this true? My theory is that when using a 35mm adapter, the DVX's internal lens will never change focal length so its backfocus shouldn't be an issue. Is this correct?
Many thanks,
Jack
Right, once the stock lens is correctly focused you never touch it again. Unless you have to zoom in to crop for vignetting between different lenses.
