Any suggestions on what settings i should shoot with to turn the image in black and white afterwards using final cut?
Can i use these settings as optional black and white so that i choose after the shoot if i should turn it into b%w?
thank you papa, will try it out, does this setting also give a good color quality in case i want to keep color or will it bind me to b/w. I guess testing is key.
And thanks!
Also remember that shooting B&W is not the same as shooting color. You need to light properly, choose appropriate colors in your shot (understand which look darker/lighter in B&W; often red looks darker than actual black); if you're using makeup, it should be adjusted accordingly.
