[FS: General] Azden SGM-2X - Omni/Supercardioid Microphone --- MINT --- This is a GREAT Mic!
Status
Not open for further replies.
questech
This is a Fantastic Sounding Mic for the Money
Hi Guys & Gals!
This is an eBay auction so this thread will be closed. See/Bid, Ask Questions on this microphone here: http://tinyurl.com/8vmx39c
Auction Description:
Your bidding on a New - Out of the Box Azden SGM-2X. I purchased it new from a vendor, but it came without the original packaging, and after I tested it to make sure it functioned properly, I shelved it in my climate controlled gear cage. Because I don't use my personal equipment on the job, my personal gear never get's used, so this thing is literally just like new... mechanically and cosmetically Mint!
I own a production company, and we have all top-of-the-line equipment, so I have the luxury of being able to test my personal gear against the stuff we use every day in the field. I can say that this Azden mic stands up against equipment that is much more expensive. Maybe I have the opposite of a lemon and this mic is just exceptional, but it really performs well!
Because I knew I was putting it up for auction, I recently tested it (Azden SGM-2X) against a Sennheiser ME66 K6, and one of our Rode NTG-3s. I thought that the Azden sounded every bit as good as its more expensive counterpart, the ME66. The NTG-3 did sound better, but what do you expect???
What's Included:
* Battery Operated Power Module
* Omni Directional Short Capsule
* Supercardioid Long Capsule
* Foam Windscreen for the Short Capsule
* Foam Windscreen for the Long Capsule
* Dead Cat Wind Screen (goes over the foam windscreen - $39.00 value)
NOTE: This mic system only comes with what is pictured in the photos, it does not come with a shock mount.
As always, if you have any questions, please don't hesitate to ask!
Happy Bidding...
Technical Specs:
  • Frequency Response: 40-20,000Hz
  • Low-Cut Roll-Off:: 6dB/Octave @ 200Hz
  • Sensitivity: Super Cardioid -39dB re 1V/Pa
  • Sensitivity: Omni-directional -45dB re 1V/Pa
  • Impedance: 680 Ohms @ 1Khz
  • Max. SPL Input Level: 110dB
  • Signal to Noise Ratio: 70dB
  • Dynamic Range: 85dB
  • Battery Type: AAA (1.5V) - use alkaline battery
  • Battery Current: 0.2mA
  • Battery Life: 1000 Hours w/Alkaline Battery
  • Weight w/o Battery: Long + Short Barrel 6.5oz (185grams)
  • Weight w/o Battery: Short Barrel 3.9oz (110grams)
  • Dimensions: Long + Short Barrel.......16" (400mm) length
  • Dimensions: Long + Short Barrel.......0.83" (21mm) diameter
  • Dimensions: Short Barrel..............8.4" (212.5mm) length
  • Dimensions: Short Barrel..............0.83" (21mm) diameter
  • Output Type: 3-Pin XLR type
Status
