AZDEN FMX2 2 Channel Field Mixer Like New
Zephyrnoid
AZDEN FMX2 2 Channel Field Mixer Like New- but I can't find the box.
$170 shipped to CONUS
Paypal Payment to > Vivieyen@mris.com
Includes Instructions. Perfect for mixing two audio sources into the Canon HV20 's 2 Channels via the Mic In- 3.5 mm socket. Ideal for Mixing or controlling two audio sources for any Camcorder with either XLR or 1/8 (3.5mm) Mini mic inputs EXAMPLES> -mix two lavaliers (wired or wireless) -mix a lav and a shotgun (either camera or Boompole mounted) -mix a wireless handheld and a lav or a shotgun. -mix line input plus a shotgun, or a lav, or a handheld Does what Beachtek does but with more power and Output choices. You get an unbalanced out plus two balanced XLR outputs and a headphone amp in one box. Includes a two position belt clip Bought it from here... http://www.alphasound.com/index.asp?...ID=266FEATURES - Azden fmx-2 Portable 2-Channel Field Mixer with Configurable Output: All metal design for supreme durability Attaches directly to camera or can be worn on belt 2 balanced XLR mic/line switchable outputs, stereo mini-jack (3.5mm) output Twin peak level input indicators, monitor output with level control Includes belt clip Uses one 9v battery DETAILS... The FMX-2 is a portable, 2-channel field mixer designed for the professional videographer. The small (3.75" x 1.625" x 5"), all metal, battery operated (single 9V) mixer can be attached directly to a camera with provided velcro or belt-worn using the included 3-position belt clip. The FMX-2 is a versatile, 2-channel mixer with XLR inputs and outputs for larger cameras in addition to a mini-plug output for high-quality mini DV cameras. A highlight is that Azden has designed the FMX-2 with configurable output. This means, for example, that 1 microphone can be mixed to both outputs as well as either single output while 2 microphones can be mixed to either single output or mixed together to both outputs. The FMX-2 features 2 balanced XLR mic/line switchable outputs, a stereo mini-jack (3.5mm) output, twin "PEAK" level input indicators, a "MONITOR" output (stereo or mono) with level control and a POWER On/Off/Low Battery LED indicator. FMX-2 SPECIFICATIONS Frequency Response Main and Unbalanced Output: 40-17,000Hz (-3dB) Monitor Output: 50-17,000Hz (-3dB) Noise Level Mic (-50): -55dB Line (+0): -57dB T.H.D.: 0.15% @ 1KHz MIC Input Level Electronic Balanced: -50dBu MIC Output Level Switchable Electronic Balanced: +0/-50dBu Unbalanced Output 3.5mm Stereo: -50dBu Monitor Output 3.5mm Stereo (Max Load 16 ohm): -18dBu Main Output +6.5dBu with 600 ohm load 0dBu ref @ 0.775Vrms +13.5dBu with 1000 ohm load 0dBu ref @ 0.775Vrms Unbalanced Output -32dBu with 600-1000 ohm load 0dBu ref @ 0.775Vrms Battery Type/Duration 9-Volt Alkaline (006p type): 6 Hours Current Draw 38mA nominal 50mA maximum Size 42H x 130W x 103D mm (1.65 x 5.1 x 4.05 inches) Weight with Battery 21.2 ounces (601 grams) Retail is $300 http://guygraphics.com/GGPROD-17840.html PayPal or USPS MO
