Five matched Azden components for a complete VHF wireless mic system. Components consist of:
One WR2-Pro receiver. Allows the use of two mics simultaneously. Complete with antenna and standard shoe mount. Operates with all transmitters of the “Pro” series. Each channel is monitored and controlled independently. Uses one 9 volt battery.
One WR-Pro receiver. Includes antenna and a standard shoe mount. A single channel receiver with a choice between the two “Pro” reception frequencies. Operates with all transmitters of the “Pro” series. Uses one 9 volt battery.
One WM-Pro bodypack transmitter. Two switchable “Pro” transmission frequencies. Complete with omni-directional lavalier clip-on mic and belt clip. Uses one 9 volt battery.
Two WM/T-Pro hand held mic transmitters. Each has two switchable “Pro” transmission frequencies. Each features a standby switch to mute audio and rubberized coating for reduced “touch” noise. Uses a single “AA” battery.
All the above “Pro” items incorporate the same two frequencies: 169.445MHz and 170.245 MHz. Frequency is selected as desired for each of the above components.
All are in excellent condition, fully operational and are in “as new” condition. System being sold simply because I do not need it.
Sold only as complete set. $250 plus shipping.
