At work I use Magic Bullet looks all the time for sweeps promos. That’s about it. Even FCP’s color correct three way can work very well for grading. Put the waveform scope up and adjust the blacks so they touch the bottom. Kinda crush them a little then mess around with saturation and such. It takes time and practice. A good external monitor is required to get it right but the scopes help a bunch.
Red Giant has some very good tutorials for Colorista on Vimeo. Colorista II is a great tool and I use that primarily when I have the time to spend on grading. Very powerful masks. Check em out. This is where you make good shots great. I never use a frame of video that hasn’t been CC. Its just part of the process for me and I enjoy grading.
Take those washed out clips and grade them. Bring the black levels down, boost the mids, add some saturation and they will look very different.
I actually did that yesterday with my AF, which I've owned for all of three days. I was concerned with the talk I've seen about the codec not being up to color correction like P2 is due to the lower data rate. So I took the camera out and shot a couple of scenes (at 30fps for the normal data rate and overcranked to 60 for the higher rate), then came home and applied a Magic Bullet Look (Mishandled Negative) that would be classified as heavy grading. Here are the results (beginning is all graded footage at two different data rates, end is ungraded clip VS graded clip).
http://exposureroom.com/members/mainstreetprod/0eb34108fb5d4454a05e4c5575fcce32/
I was very pleased at how well the codec handled the heavy grading. I saw absolutely no difference in the graded clips between the two data rates. I'm a firm believer now in the "shoot flat and grade later" philosophy. All footage shot with Abelcine scene file "Range".
I went to the set of The Voice a couple weeks ago for a promo shoot with a HPX370. That camera isn’t nearly as good image wise as the AF-100. The set looks amazing with the lighting setup. I balanced my camera and shot my promo. When I got back to San Diego I imported the footage and was surprised how much blue cast I had in all the shots. I didn’t get all freaked out because with a few clicks and adjustments the stuff looked really good. All done only with FCP 3-Way CC. I showed one my colleagues and they couldn’t believe the difference. This happens all the time. Those stage lights played havoc on the lens/sensor. Light was bouncing around and even flaring the lens. No big deal. Fix it in post.
Can’t post any images from the shot until after the Super Bowl. Sorry.
It’s not the camera John. Take the bull by the horns and don’t let the camera tell you how it will look. Now get out their and grade some footage!
Watch some of Stu Maschwitz’s tutorials on Colrista II. Even if you don’t use Colorista its a great lesson in grading. Grab a beer and enjoy.
http://vimeo.com/channels/coloristaii
Wasn't my intention to be patronizing- but I can understand how it might sound that way so maybe poor phrasing on my part. Of course there are GH2/DSLR users who are no less professional than AF or any other camera user. No- gear doesn't define one's abilities.
Although these shootouts are a great resource and very informative- they do lack any details of the gear outside of their sensors. This info would give a well rounded evaluation for each camera (to PB's credit he has said as much in his introductions). Sure, it's not his responsibility to cover everthing, but a little blurb during his wrap up would remind potential buyers (and owners) not to get tunnel vision. After it's all said and done- you might end up with a franken-rig for close to what an FS or AF costs. And all in the quest for the sharper sensor.
