ZephyrStar
I'm just curious as to whether anybody here is familiar with/has tried this method. These softwares/codecs are open source projects, but from what I can tell (and my experience processing animation footage with them) they are worth checking out.
First off, you have AVIsynth, which is a frameserver program. It allows you to write a script through which you can set parameters such as video/audio sources, filters, etc. The script is just plain text, with the extension .avs, and it can be loaded up the same way you would load any other media file.
You can get a plugin for it called FFmpeg, which *should* allow you to frameserve AVCHD. From there you can load the .avs into your NLE, or transcode it using Virtualdub. There is a freeware open source codec called Lagarith, which claims to be lossless and can encode in a few colorspaces.
I find that Lagarith footage is very easy to edit with in Premiere, and seems to be frame accurate. Again, not sure on the quality, but to me it looks just fine. If anybody is interested in trying this out, I can point you to these programs and give you a sample .avs script to get you started.
