Avid Xpress Pro V4.5.1 for Mac and Win XP is now available at: http://www.avid.com/products/xpresspro/
Tons of improvements and great features. Some of which include:
* 24p/25p PAL support - Avid supports 24p and 25p PAL resolutions on Mac OS X and Windows XP. To capture with 24p, you need an Avid(R) Mojo(TM).
* Native Windows Media 9 export - This release supports exporting to Native Windows Media 9, including "up-res" to HD formats (XP only)
* Digi 002(R) and Command|8(TM) support - The Digi 002 and Command|8 can be used as control surfaces for your Avid editing system. They can also be used as controllers for automation gain recording.
* Digidesign(R) Pro Tools(R) support - Avid supports exporting sequences to Digidesign Pro Tools.
* DVCPRO 50 Edit - You can now edit (no capture) DV 50 material in Avid Xpress Pro.
* FluidFilm - The FluidFilm effect templates allow you to create a film look from interlaced video sources. The FluidFilm effect templates appear in the Timewarp category of the Effect Palette.
* J-K-L ratcheting - Allows you to slow down or change play direction one speed at a time.
* Keys tabs - The Keys tab in the Capture Settings dialog box allows you to specify a default duration for subclips created during capture and to customize the commands mapped to the function keys on your keyboard that are used during the capture process.
* MXF support between Avid, Digidesign & Softimage app- This release supports MXF file format. You can also now perform audio and video conversion between OMF and MXF formats.
And much more……
And much more……
