Avid MXF problem
section33
Hi Guys,
First post here... and already I need your help...
I've taken a project from a Mac version of Avid and am trying to get it onto my PC version. it all loads up but says media offline, this is because it is still searching for the media files in their old HDD names (for example C:).
I'm sure the answer is probably looking me in the face but how do i change the drive it is looking in?
Gary
If you are working with p2, a simple re-import of the p2 files into a new bin should work. But you probably tried that already..?
Also make sure to locate your files in C:/Avid MediaFiles/MXF/1/<files>
You could have many folders under MXF 1,2,3, etc.
After you've done that, then in each there's two msm database files. Move those to your desktop and restart Avid. Avid should rebuild the database and your files should be relinked.
