Jim Anderson
Jim Anderson
HDX900 and HVX200 in 720/30p Help
We did our first shoot with an HVX-200 onto P2 cards and an HDX-900 in 720/30p (onto a firestore). Now that I'm trying to bring the footage into Avid I've realized that the HVX200 was actually shooting 720/30pN to save card space, while the HDX900 was shooting 720/30p. Avid will only work with 720/30p in a 720/59.94 project and 720/30pN in a 720/29.97 or 1080/59.94 project (the two format framerates cannot be mixed in the same timeline). So, my question is: do you know of a way to convert the 720/30p footage (which avid reads as 59.94 frame rate) to actual 29.97 frames without losing resolution?
Luckily we also shot the HDX footage to DVCPRO-HD tape so if we can't work with the 720/30p Firestore MXF/P2 footage we could capture the tapes-- if we do this does it make sense to work in a 1080i/59.94 project?
Is there any way to do a pull-down of the HDX-900 footage which, even though was set to record 720/30p, actually recorded all duplicate frames which shows up under the properties of 720/60p? We need to convert the HDX-900 footage to 720/30pn to cut with the HVX-200 footage. We have learned that when shooting with both these cameras to avoid the native format in the HVX-200 but still have to deal with footage from 2 shoot days. I have Cineform Prospect HD and AE CS3 for conversion. Any advice would be greatly appreciated.
__________________
Jim A
__________________
Jim A
