nyvz
I posted this in another thread, but I thought I'd give it its own thread as well so people actually see it since some might be interested:
I just pulled out my camera and Hyperdeck and did this quick comparison, hope it helps illustrate the AVCHD vs Prores question.
http://www.noahyv.com/temp/FS700HYPERDECK2COMPARISONS.jpg
Comparison #1: Broad daylight, static camera, normal settings with moderately detailed scene
As you can see, especially looking in the shadow areas, even in a high key scene with little noise, Prores holds detail and some noise structure a bit better in shadows. AVCHD is a bit muddier. AVCHD does quite well in this situation since its weaknesses are noise and movement, but even here the differences are visible. Notice even here, the edge of the red bricks have better separation in Prores than AVCHD.
Comparison #2: High ISO
Similar results but the loss of detail in the AVCHD is greater due to the increased noise level. Higher noise level forces more detail smoothing for AVCHD, which reduces contrast, especially pixel contrast. Prores holds pixel contrast better and noise structure.
Comparison #3: Extreme low light, Higher ISO
AVCHD does not do well at differentiating between noise and real detail, both are lost. This is a bit extreme as it is high ISO and underexposed, but it shows you where AVCHD really breaks apart. AVCHD acts as a heavy denoiser, which some people may like to some degree, but there is a significant chance of losing real detail and recording a lot of muddy shadows.
Comparison #4: Broad daylight, moving camera, increased shutter
Here is another place where AVCHD falls apart a bit. It is so efficient because it uses similar information in previous frames to define the current frame, but when the frame changes more quickly, the codec displays errors and loss of contrast. There is a lot of mud and odd looking edges where the codec may be trying to keep detail that seems similar to previous frames.
I noticed in the last test that parts of the frame were quite a bit worse, as there the codec would fall apart in even higher motion, but I chose that frame and crop because it was similar to the previous tests. I was a bit surprised how much the codec had trouble with high motion. This was surprising since I figured that frames in motion would be easy to compress since they were quite blurred.
