Continued confusion amongst codecs...
using panny tm900 so avchd at the moment.
Instead of going crazy over all the info online about which is the best codec for quality and editing, which left me more confused, i'm going to setup some tests, and just record clips and covert to all choices and compare them by eye.
that being said, i just want to make sure i'm setting up things correctly before i make comparisons.
The results are in, and its a bit disappointing.
i'm on a MBP late 2008, dual core 2.66, 4gig ram, latest FCP.
the setup was layering a single video clip on top of itself with 'overlay' composite mode
RT unlimited
AIC & pro res showed no difference between performance. Playback frame rate even at QUARTER can not play without a playback error immediately.
DVCpro on the otherhand, could play the setup back, but only at half playback frame rate, not full.
i was hoping AIC would work well since its smallest file size.
Very disappointing.
If anyone can chime in and confirm would be much appreciated.
Thanks!
1. if recording avchd 60i, i should select 30fps when converting, since 60i is 30fps.
2. just realized that i can convert to dvcpro, which i predict will be easier to edit on my MBP (2 core). when i convert from avchd to dvcpro, i notice that there are several different codecs
- dvcpro 1080i 60
- dvcpro 1080p 30
- dvcpro 720p 60
- dvcpro 720p 50
naturally, the right one for me would be 1080i 60. so you have all these different codecs, and DVCpro is one, but within that you have all these specific ones as well. Out of curiosity, why?
- dvcpro 1080i 60
- dvcpro 1080p 30
- dvcpro 720p 60
- dvcpro 720p 50
RT unlimited
Very disappointing.
Thanks!
