Eithcowich
Does anyone have experience importing AVCHD into Avid media composer 4? A workflow tutorial would be great!!!
you still cannot use AVCHD files natively on MC5. you have to import to your choice of DNxHD (it takes time and might get to be X8 bigger than original AVCHD).
but i would also be happy to hear of a good workflow. i still have some decisions to make..
- is it possible to finalize editing in the lowest DNxHD and replace with original AVCHD files when going to After effects ? (that could save a lot of space)
It would nice if there is a better workflow.
I also came face to face with this AVC wall, as I call it. Much of what I do is somewhat to very time sensitive, and it took me well over 3 hours to transcode 1.5 hours of AVCHD into Avid MC5. So I bought a Nanoflash. Now it sees and plays those files instantly through AMA, but appears to still require a transcode on export. I really wish there were a same as source option, or QT reference available in AMA.
i had the chance to shoot with af 100 for a day and i own MC 5.0 and all i did is just import the files i shot..
i opened a 1080 25p project and imported the files as DNxHD120....
i opened a 1080 25p project and imported the files as DNxHD120.... if you want you can import it as 185 or whatever res you want... after all your files are 24mb/s...
imports might take some time... But, in the long run... trust me, using files without import with AMA will kill, even the fastest system...
