Scott Whitney
Hello, question for anyone that can help. I recently shot a project with the HPX 300 using AVC_Intra 100, shooting in 720p.
So....I've been logging and transferring footage into Final Cut Studio. I understand that Final Cut doesn't have a AVC Intra easy-setup selection and I've read where users suggest using Apple Pro-Res as a workaround selection. I did that.
When I drag clips onto my timeline I'm getting the following message:
Attention this clip does not match this sequence's settings or any of your sequence presets. For best performance your sequence & external video should be set to the format of your clips you are editing. Change sequence settings to match the clip settings?
I'm looking at the item properties of my clip....1280x720, video rate 29.97. I'm looking at the item properties of my sequence...the exact same. Am i getting that message just because the compressor is different? AVC Intra for the clips, Apple Pro Res for the sequence?
Thank you.
Thank you.
