Hello all,
I just got an HMC150 and have started to test the workflow process and am wondering where/if it can be streamlined. I filled an 8gig card with 49 minutes and 46 seconds of footage shot at 720p 60.
Using Final Cut Pro 7 I logged and transferred the footage and got a 49.37GB clip.
The format is:
Apple ProRes 422, 1280 x 720, Millions
16-bit Integer (Little Endian), Stereo (L R), 48.000 kHz
FPS: 59.94
Data Rate: 141.94 mbits/s
I understand that transcoding the AVC footage to Prores is going to result in large files, but 50 gb for less than an hour is crazy! Is this what I have to work with, or are people transcoding the Prores footage to something smaller that is still editable natively in FCP 7? If so what software/settings are you using to encode?
Thanks!
The format is:
FPS: 59.94
Thanks!
