Mike Sertic
So I am still experimenting with my scene file setup on the HMC40, using the Cinelike D gamma setting. One of my primary uses for the camera will be shooting surfing in bright daylight, which can be challenging in terms of preventing blown highlights in the whitewater (big problem) or surface reflections (small problem).
For exposure, I have been able to get good results by using zebras and setting the iris manually, but I am kind of struggling to get proper exposure using the auto modes (manual exposure only is not an option for me because I will soon be using the camera in a housing which does not have an iris control and at times I will have inexperienced filmers manning the camera and need an idiot mode).
First question, I have Barry Green's HMC150 book and it mentions that the A.Iris Level setting in the scene file will bias the exposure, and that each increment on the setting is equivalent to approximately 1/6 of a stop, is that the same in the HMC40? It has the same -10 to 10 range as Barry discusses for the HMC150.
Second, while reading the Panasonic scene file white paper for the HMC150, they discuss that when using the Cinelike gammas you should "adjust the iris to reduce the video level to approximately 1/2 of the normal video level". Does anyone have any idea what that A.Iris Level setting that would correspond to?
