audio
  • Start date Start date
G
Guest
Guest
hi just got my 100a nice stuff, i however would like a nice person to explain the audio controls and also tell me how to isolate a shotgun mic that i have and disable the standard mike.. ive been a grip for ten years ug ug, so bear with me....thanks
Re: audio
hey... what you want to do is switch both input switches to input 2. Then set one level (the little pot dials) high, and the other a bit lower. That will give you a backup track of the same audio at a lower level incase you peak.
Re: audio
I also use a shotgun, set to both channels, i'll try that too.
Another method is to use the shotgun on L or R and the other the camera mic.
yes i know camera mics are inferior, but for close audio, aint that bad.
besides its a good back up
