Sorry, but I can not recommend any mics in the $20 price range.
So I should not even consider Audio Technica ATR-3350? Is it really so bad?
Do these mics (Oscar Soundtech 801/802) require phantom power (I cant find them on BHPhoto)?
The ME2 is basically that comes with the g3. But Its not very good....
It looks like the H1 can support and will provide plug-in power to a mic which requires it so, just about any lav designed to work with a wireless will work.
Sort of, the NTG2 requires Phantom Power. The H1 supplies "Plug in" power, (aka, bias power) a much lower voltage and different configuration altogether.I tried to plug my Rode NTG2 and it doesn't provide power for it, but maybe lavs needs less power?
That said, if the Rode NTG2 has an internal battery option, use a battery instead.
Yes, it has battery option, I'm just wondering if Sennheiser ME2 lav (which has not battery option) will work with my Zoom H1.
Modern Lav mics will generally be powerable by "plugin power".
[snip]
Plugin power (if it exists) is almost always found on 1/8" jacks. Actually I don't know of any other connector that is wired for plugin power.
