Hi All,
I've come across a sync issue I first saw last year, needing largely manual sync of a 2 hr (finished length) project. Back then I considered it an equipment issue (Panasonic Standard def output). The camera output (provided to me transcoded into h.264) would sometimes show two identical frames in succession, which I assumed was somehow related. Hopefully someone has seen this and knows a fix, because now I need to sync 50 hrs with the same 'driftlike' issue, though I havent seen duplicate frames this time.
Basically the only decent audio track of an event is recorded to a standard def Panasonic, with 2 AVCHD/AVCCAMs to sync via PluralEyes 3.5. The AVCHD includes spanned clips which seem compatible, but sync is an issue. As time goes on, the SD w/ audio seems to play longer than the HD footage, getting out of sync over time. Everything is 29.97 fps, and the same thing happened with a 5DIII previously. Audio sampling is all 48k and the frame difference over time doesn't seem to fit any frame rate, drop frame, etc explanation that I can find, so I'm stumped. Any thoughts?
Thank you!
Thank you!
