Marshallarts
This has happened a few times today with a project involving DV footage. I recorded footage a few years ago probably in a clamshell, I'm not sure the exact format but it is DV (on a Mini-DV tape). I'm using my HV20 to import it into my MBP using FCP6.
Something must be wrong with the source audio. After importing the clips the audio needs to be rendered before you can hear it. It then works fine.
But if I create a new sequence, even with the exact same settings, and paste anything from my first sequence into it the audio is slowed down. But the clips still have the same length????? There is no red bar or need to render. It's just slow?!
I can't find any additional setting that would explain this. Of course if I drag the original clips from my bin in the new sequence I get the red bar and have to rerender.
