Audio Scrubbing
Norm_Li
Is there a hidden Audio Scrubbing feature in Vegas 6 or 7 that I am not aware of that is similar to hearing frame by frame audio from Premiere or FCP?
Norm
Starting with Vegas 6, dragging the playhead at the top of the timeline will scrub audio. Using the left or right mouse button as you drag the playhead will give you different types of audio playback.
IMHO, it's not as good/simple as other NLEs (FCP, Premier), but at least we get something :)
Hi Norm
Use the scrub control in the track list
Drag the scrub control to play scan through your project forward or backward from the cursor position to find an edit point.​
You can drag the yellow Normal Rate indicator to adjust playback speed when you click the Play
or Play from Start
button.
Scrub on the timeline
  1. Hover over the cursor in an area of the timeline that does not contain an event and press Ctrl. The mouse pointer is displayed as a
When the Allow Ctrl+drag cursor style scrub over events check box on the
General tab of the Preferences dialog is selected, you can scrub with the mouse even when the cursor is over an event.
  1. Drag left or right to scrub playback.
Scrub using the keyboard
Press the J, K, or L keys to use the keyboard as a scrub control.​
Item​
Description
J​
Scrub reverse mode. Press again to accelerate the playback rate.
K​
Pause.
L​
Scrub forward mode. Press again to accelerate the playback rate.
Press and hold K while pressing K or L to emulate a shuttle knob mode. Press K+J to turn the knob to the left or K+L to turn the knob to the left.
