Audio problems with Channel 2
jchenier
Anyone have problems with Channel 2? Suddenly, in the middle of a shoot back in September I lost everything in Channel 2. I couldn't use an input or even the camera's mic. The only thing I could hear was static-like noise, like something in the audio was shorting out. Thankfully the camera was still under warrantee and it was fixed.
Now, a couple of months later, same problem, same channel. Is this happened to anyone else? I can't isolate what's happening, since it started happening after I was shooting using only the camera's built-in mic. Pushing on the handle seems to affect the static, almost like it's a short.
Anyone?
Justin
www.beyondtimemedia.com
Re: Audio problems with Channel 2
Justin, it sounds like it needs to be repaired again. I would tell the service center your idea about it being a short, maybe they can fix it for good?
Paul
It's going back tonight... hopefully they cover it under warranty, since it was an original waranty issue. I just can't figure it out...
Justin
