Dylan Pfohl
The audio is lined up fine when playing back in camera but after converting in toast it is about 10 frames off. I have tried just about every combination of frame rate and codec possible with no luck, also contacted roxio tech support with the same result.
Searching the forum I found others with the same problem but no solution, is that still the case? Obviously I can fix it in post but if I have to give the footage to another editor, they will not be happy about having to move all my audio 10 frames over.
Can anyone help me?
Can anyone help me?
