tacotim
Just a bit of a warning about VFR mode, the audio meters as well as audio out the headphone jack continue to function when in Variable Frame Rate mode, even while recording, but no audio will be recorded. This happens even if you are set to 24 fps!
As near as i can tell the audio meters and headphones are always active, but the only way to record audio is to set VFR to off. I could see this catching some folks, you are rolling 24fps, audio meters are bouncing, you hear good audio on the headphones. but when you stop rolling and play the shot back, no audio.
-tim
-tim
