Audio Limiter and input handling
Josch
Often the automatic audiolevel setting of cameras produce pumping. Switching off the automatic, you have to lower the input level so much that at 16 bit you give away a lot of resolution (not so much of a problem in 24 bit, but still.....)
It would be nice to have the 3 options Auto, Auto off, and Limit. And for the 4 inputs of the RED it would be nice to have 4 mono, or 2 mono 1 stereo, or 2 stereo pairs. This grouping is important for the limiter or compressor to function correctly.
Apogee for example gear has very nice working level limiting on its devices that allow you to record fairly hot levels without driving into digital distorion.
All the best,
Jochen
When I record at Hot Import Nights, the bass in the cars is too deep and loud to be picked up without distortion by my mic. I have a Canon GL1. It would be good if a dummy like me could record deep bass from subwoofers without knowing how to attenuate a mic. My camera has a mode to limit wind noise. RED should have a mode to record bass. I am not serious though. No one would use such a thing except me, or would they?
That would have to be an analog limiter, because if you overdrive the Red´s AD-converter, everything is distorted anyway.
Some mics have a "Trittschallfilter" (dont know the proper english term - something like a highpass for filtering out body noises from the micstand)
Try that, although the subwoofers usually go up to a 100 Hz, but normaly most of the subwoofer energy is around 70 Hz.
