I have a dvx100b with two external mics (both phantom powered) connected to inputs-1 and input-2. Both mics are Okatava MK012. I switch on mic connected to input-1 and set the volume level so I get 2-3 red bars on the audio channel meter. This is my reference volume for that channel and the mic is attached to the camera. Everything is OK as long as I only have this one mic turned on. My problem starts with I turn on the mic connected to the other input (input-2).
The Mic on input-2 is on a 20 foot xlr cable positioned on a boom directly above my audio source. As soon as I turn on input-2 and have dialog coming through it, the volume meter strength on input-1 suddenly drops off significantly. Behavior is as follows: once one of the mics is the dominate mic (when it receives a significantly louder audio source) then the camera automatically lowers the volume input on the other mic. Then when I turn off Mic on input-2 or distance it from the sound source, the meter strength on iput-1 automatically returns back to my reference level.
When I place both mics side by side so they are receiving the same relative audio source strength, turning on the second mic on input-2 does not seem to affect the volume level meter strength for the mic on input-1's channel. I am assuming this is because neither mic is dominate.
Can anyone help explain the unusual behavior I am experiencing when connecting two external mics and one channels volume level is automatically lowered when a 2nd mic becomes dominate in terms of receiving a louder audio source?
