Audio help on DVX100A
Parnelly_Jones
I just bought my DVX100A. I need to set the onboard mics to mono and i cannot figure it out if it is even possible. I would be greatful for any help.
Re: Audio help on DVX100A
[quote author=Parnelly_Jones link=board=Events;num=1088363960;start=0#0 date=06/27/04 at 12:19:20]I just bought my DVX100A. I need to set the onboard mics to mono and i cannot figure it out if it is even possible. I would be greatful for any help.
Thanks[/quote]
Why, I mean do it in post.
I will not be posting for this pourpose. I will be doing legal depositions and will be turning the tapes over to the contractor. they require mono recording and i was trying to cheap out on a shotgun. the mic is for back-up only.
The onboard mic is stereo.
If you want to have only one track of audio, you could try setting channel 1 to INT and channel 2 to an external mic, and just not have a mic hooked up there... I don't know how well that will work...
since i am not using the camera to record i will use a y connector to combine l and r to a mono plug. I just thought there may be a way to switch the audio to mono
Thanks for the help
