Michael Terri Studios
I am thinking of using the Rode NTG-1. To catch ambient audio at the reception will I have distortion problems considering how loud reception music is... if so I will purchase a pad.
Auto setting is not good at all. I used it on old broadcast cameras. It pick up noise when the ambiance sound is low and can peak when a loud sound pop in.
The 150 has the same limiter as the DVX100, but it is less strong and can easily peak if the sound is strong.
About shooting weddings, I always use a Rode NTG-2 on a channel and a Seinnheiser ENG 100 G2 (it's now the G3 series) wireless transmitter on the other channel to use the output from the DJ's mixer.
If you want a professional audio, invest in a wireless transmitter. It will improve dramatically the final result.
r BTW said:A pad is a device that attenuates sound by a preset amount.
The first line "|" is a white line and is always showed. It indicates -12 db. The second one is a "red" line and indicates 0 db and the peak level.ive only just read that the FIRST red line is still -12dB! Wish I'd have known this before recording an entire wedding ceremony at -12dB-14dB!
