wanted to shoot some 10 bit with a Atomos shogun 4k however am having no luck with my settings cant get image on the shogun have watched several videos all seem to be of the shogun flame mine is the original black one 4k supports up to 30p4k i have 6.6 software installed on the shogun settings on the DVX are as follows
IN System Mode
System Freq 59.94HZ
Output bits 422 10 bit
Output format uhd 2160 29.97p
extended sens off
camera number set 1
User switch 1 auto rec
in Vlog
in output set up
Output sel HDMI
resolution System
Sdi remote on
remote relink off
sdi EDH off
sdi audio chain chg 0db
hdmi UHD output limit 29.97p
hdmi TC output on
volume on
and i get no signal if anyone can help would appreciate it i am wondering if the hdmi cable is bad however i used it a month ago with a monitor only so not sure what im doing wrong here thanks in advance
IN System Mode
System Freq 59.94HZ
extended sens off
camera number set 1
in Vlog
in output set up
Output sel HDMI
resolution System
Sdi remote on
remote relink off
sdi EDH off
hdmi TC output on
volume on
