I am curious if they will have touch screen auto focus in conjunction with the monitor. That would be nice for run & gun.
Although I love the idea of owning one of these, I will most likely only ever rent. If there were a cheaper, compact, non monitor modual that recorded 4K to CF fast, I would heartily plop down $400-$500 for that~
They said today that they slipped a couple of weeks. They are in beta right now and have made a few modifications to the Shogun...
One change is 4K @ 60p which was partially enabled by replacing the heatsink with dual heat pipes! This also apparently made the unit lighter in weight!
on another note - Blackmagic is releasing a 4k hdmi to 4k sdi converter which you can probably use with the O7Q and run off a p tap - so there are soon other options to get 4k out of your a7s.
